It is currently Wed Aug 20, 2025 10:25 pm
 Post subject: Conversion
PostPosted: Sun Dec 29, 2013 8:07 am
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
So I have this very old, very ugly, very weak buffer grinder setup that I inherited from my grandfather. I'd like to leave most everything the same, but lengthen the arbors and add larger buffing wheels/remove grind stone. I figure the 1/3 HP ancient motor should be fine right? If it can push a grindstone (as long as you don't apply too much pressure) it should be fine for buffing.
Where can I find longer arbors to fit this thing?
Pictures to follow from tapatalk because posting photos any other way is a PITA.
 Post subject: Re: Conversion
PostPosted: Sun Dec 29, 2013 8:09 am
First name: Joey
Last Name: Holliday
City: Palmetto
PostPosted: Sun Dec 29, 2013 9:00 am
Last Name: Hodge
Grainger, McMaster Carr, both a good starting point. Lots of other places as well.
Bill Hodge
PostPosted: Sun Dec 29, 2013 10:05 am
Maybe you could find a coupling nut and add some all thread extensions to the existing arbors. Then if you find it doesn't work out it wouldn't take much to change it back.
Prices on coupling nuts (and most hardware) vary quite a lot depending on vendor, so be sure to shop around.
PostPosted: Sun Dec 29, 2013 11:22 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
You might fine 1/3hp a little light.
When I first built my buffer that is what I used, and was not able to get a decent buff going without stopping the motor.
I recently swapped it out with the 3/4hp motor from SM and now it works great!
(curiously, it was cheaper to get the motor shipped here from SM than from my local furnace motor suppliers....go figure....)
PostPosted: Fri Jan 03, 2014 9:06 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Before you spend too much money on that arbor, take a look at the Grizzly Buffing arbor- $100.
[urlhttp://www.grizzly.com/products/W1681][/url]
I'm using several of my Grandfathers tools as well, but I think the 5/8" shaft size on those bearings
is going to severely limit your options.
Gene
PostPosted: Fri Jan 03, 2014 9:52 pm
First name: duh
Last Name: Padma
complete mandrels...
http://www.grizzly.com/search/search?q=buffing%20machine&cachebuster=436324180018169.44
cheap like borsch...no messing around... saves time, energy and $.
Users browsing this forum: dofthesea and 35 guests
